pontiactarestorer
- Oct 8, 2009
- 2
I have a 92 OMC 5.8 cobra that cuts out under a load, 2000 rpm on up. The fuel system had water in it. I drained the tank, rebuilt the carb, changed the fuel filter twice. I suspected leftover moisture, but by now it is cleared out. The coil was bad, so i replaced that. I replaced the ignition and kill switch. Good connections at starter relay. good connection at the main harness plug. It fires up and runs great. Just when i give it 3/4 to full throttle it suddenly and quickly cuts out only for split seconds. And to make it more crazy it seems to only do this when first using the boat. if i keep on running it eventually it stops doing this. My next test will be running a jumper wire to the ignition for a dedicated power supply. after that i can only assume it is either the Distributor pick up coil, or the shift interupter module. I would hate to guess at either of those for they are Expensive. Any help will be appreciated!
