5.8l OMC
ba0814
Need to replace lower unit on my 5.8L cobra. found a 5.0L cobra lower unit, is it compatable?
danond
Re: 5.8l OMC
Check the gear ratio. It could be different. Otherwise, it's the same drive.
HT32BSX115
Re: 5.8l OMC
I think the ratio for those engines were the same some years. 1.43:1 comes to mind.
It will work fine though. You may need to put a slightly "taller" prop on it though. Run it first. then try different props. You can find (good even SS) props on ebay all day long.
Cheers,
Rick
Don S
Re: 5.8l OMC
Hold on, what year?????????? Model number is even better.
Don't forget that OMC liked to name all kinds of dfferent drives Cobra and King Cobra.
