5 blade SS
redster
I have a 22ft Reinell with a 5.7 Volvo(300hp) with volvo leg. I would like to get a SS 5 blade, which is the best type, pitch ect..
Thanks
Re: 5 blade SS
Ayuh,... Other than wakeboarding,+ skiing,... That's probably Not the best choice...
redster
Re: 5 blade SS
Not sure I understand, I pull alot of tubers and wakeboarders and skiers. What would be the best choice, I have a SS 3 blade right now.
Re: 5 blade SS
Ayuh,....
If you'd have clicked this,... "Sticky: Read This First!! "
You'd have seen This,...
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
As you can see, you've only touched on #s 5,+ 6....
It's All rather Important Info, for meaningful answers...
Thank you....;)
