5 hp on 12ft?
pstalls
How fast will i go if i have a 5 hp evinrude on a 12ft v-hull aluminum boat? i weight about 140 lbs. and fishing gear about 20 or 30 lbs. thanks
Rick.
Re: 5 hp on 12ft?
I would think in the range of 6 to 8 mph. You won't need flaps to break that's for sure. Best of luck. You might get more response in the boat forum. Rick.
F_R
Re: 5 hp on 12ft?
Yeah, about 9 or 10 if it will plane, which is probably not going to happen. Otherwise about 6 or so.
Vic.S
Re: 5 hp on 12ft?
Yes 6mph is about tops if it does not plane
Max speed in knots of a non planning hull is about 1.34 X square root of the water line length. If that is 11 ft it works out at only just over 4.4 kn which is about 5.1 mph . A light hull will go a bit faster. 6mph? with luck!
Rick.
Re: 5 hp on 12ft?
Vic.S: Where do you get this stuff from? Very informative. Rick.
kenmyfam
Re: 5 hp on 12ft?
I'm with the 6 mph as well. A friend of ours has a 12ft aluminum with a 5.5 ted Williams. Once we cleaned it out and got it running properly we got 6 mph out of it by GPS with 12 person aboard. 5 mph with 2 people and 4 mph with 3.
Vic.S
Re: 5 hp on 12ft?
All sorts of places. A lot from other boating forums. A lot by searching Google for it. Some from books.
If I come across something interesting that might be useful I make a note of the source.
wbeaton
Re: 5 hp on 12ft?
Ok, here's my guess. 10 mph or 16.5 kmh if you plane. 6-7 mph or 10 kmh if you don't.
Here is a 1954 5.5 hp on my 12.3' tin boat. Load included me (205 lbs), 2 hp back up motor (26 lbs), small tool box and 3 gallons of fuel. Mine also has a 3 blade bronze prop. It pushes me on average 10 mph or 16.5 kmh.
http://www.youtube.com/watch?v=ccYe9UziGPc
