5 hp two stroke compression. 90 and 75. Acceptable?
spamman450
I recently acquired a mid, to late eighties 5 hp twin cylinder Suzuki outboard. In my attempts to get it running i checked the compression today. They numbers where 75 and 90. This seems awfully low to me. Would it even run with this low of compression?
PS94
Re: 5 hp two stroke compression. 90 and 75. Acceptable?
I think you'd have to start it on Ether with that low of compression. :(
spamman450
Yeah i am inclined to think that its toast. It popped a couple times when i was fiddling with it, but never caught on.
Texasmark
Know nothing about the engine. Sometimes engine problems can be solved by loosening stuck rings. DeCarb is a process described numerous times on this site which decarbonizes combustion chambers thus loosening stuck rings and allowing for restored performance.
I had a chain saw and a weed eater that I restored (after I had bought new) just to see if the process worked....and it did. Should have done it before.
HTH,
Mark
