50:1 Ratios
Does anyone have an easy way to remember the oil percentage to gas for the 50:1 ratio? Example would be that for every 1 gallon of gas, you add Blank oil? I know that it is 1 pint for every 6 gallons, but often it falls above or below the 6. I was hoping that someone might have a simple way of doing the math.
catfish1
Re: 50:1 Ratios
get a jug of two stroke & look at the label on the jug, they all have mixing instructions & ratios.<br />you could have asked that question on your previous post, try not to start new threads on the same subject in the future. ;)
Re: 50:1 Ratios
Thanks Roscoe,<br /><br />To Catfish1; Sorry about the question, but I did not have the question at the posting of the first one and since this was my first use of the system I would hope it is ok to make mistakes! :(
JB
Re: 50:1 Ratios
Fireslayer.<br /><br />Mistakes are not permitted here. :mad: <br /><br />You are sentenced to 8 hours of fishing in good weather when your favorite species is on a feeding frenzy. :D <br /><br />Ooops!! You also posted a General Outboard question in a troubles forum! That's another 8 hours, and I will move this to General Outboards.<br /><br />Good luck. :)
