50:1 Ratios
Does anyone have an easy way to remember the oil percentage to gas for the 50:1 ratio? Example would be that for every 1 gallon of gas, you add Blank oil? I know that it is 1 pint for every 6 gallons, but often it falls above or below the 6. I was hoping that someone might have a simple way of doing the math.
catfish1
Re: 50:1 Ratios
get a jug of two stroke & look at the label on the jug, they all have mixing instructions & ratios.<br />you could have asked that question on your previous post, try not to start new threads on the same subject in the future. ;)
Re: 50:1 Ratios
Thanks Roscoe,<br /><br />To Catfish1; Sorry about the question, but I did not have the question at the posting of the first one and since this was my first use of the system I would hope it is ok to make mistakes! :(
JB
Re: 50:1 Ratios
Fireslayer.<br /><br />Mistakes are not permitted here. :mad: <br /><br />You are sentenced to 8 hours of fishing in good weather when your favorite species is on a feeding frenzy. :D <br /><br />Ooops!! You also posted a General Outboard question in a troubles forum! That's another 8 hours, and I will move this to General Outboards.<br /><br />Good luck. :)
catfish1
Re: 50:1 Ratios
fireslayer, i understand. myself and everyone on this forum has made the same mistakes, i just wanted to let you know how it works. <br />if your tread is at the bottom of the page or even on a different page, you can ask a question or anything you want on it and it bumps it to the top of the opening page, so it will be viewed by everyone again. <br /><br />shame on you! you are hereby sentenced to 8hrs of fishing in good weather!
jrlogan11
Re: 50:1 Ratios
A couple simple things for you.<br />1. 50:1 is 1 pint of oil per 6 gals gas.<br /><br />2. You can buy at most boating shops/marinas mixing bottles which have the measurements labeled on the side. Mine has all the oil ratios, and I just use the 50:1 scale, and it has gals of gas labeled on the side of the container. If I put in 7.5 gals, I just fill this container up to the 7.5 mark with oil (which will of course be just over 1 pint) and then I dump that much in the tank. Simple, for us simple minded folk!<br /> I like this because I can buy my oil in large gallon containers and still measure accurately and conveniently.
andrewkafp
Re: 50:1 Ratios
Careful J.B doesn't make you walk the plank...<br /><br /> http://www.tohatsu.com/tech_info/oil_gas.html <br /><br />Try here<br /><br />You guys should go over to Metric.. :( 50:1 = 20m1 per litre or 200ml per 10 litre..<br />25 litre tank = 500ml No gallons here but 4.54 litre = 91ml<br />All in 10's It's real Easy... :D :D <br /><br />You know that your gallon is 3.79l and ours is 4.54l. Just wondering who's getting the best deal on petrol ??? We pay @ 80c per litre.<br />$3.60 AUD Aust gallon. Just a bit of trivia
jimchere
Re: 50:1 Ratios
Always works for U.S. units (may need a calculator):<br />There are 128 fl oz. in a U.S. Gallon<br />There are 16 fl oz. in a pint.<br />To figure out amount of oil for any amount of gasoline use (Gallons gas * 128)/50<br />Or, written out, just multiply the number of gallons of gas by 128, then divide the result by 50. For example, 6 gallons*128=768 oz gas. 768oz gas divide by 50 = 15.36 oz oil (round up to 16oz, which equals one pint).
Luna Sea
Re: 50:1 Ratios
Just cut out the little chart and put it in your wallet. Get a measuring container marked off in ounces. I never pour it right in from the bottle. Well, not my 2 stroke oil anyways... :D :D :D
jim phillips
Re: 50:1 Ratios
I keep a plastic baby bottle and a calculater in the boat Gal.x128 Div.by 50 =oz. of oil
