Re: 50 channels for GPS /WAAS?
There are no "channels" on a GPS receiver as one would think of a receiver having different frequency channels. All the signals are transmitted on the same frequency, the L1 carrier frequency of 1575.42-MHz. Signals are differentiated by their spread-spectrum modulation psuedo-random number (PRN) sequence, which are numbered for identication 1 through 32.
There are only two WAAS signals-in-space for the NAVSTAR GPS. They are sent from geo-stationary satellites. Their position in the sky does not change. They are always either in view or not in view, depending on where you are located. The currently active WAAS signal-in-space sources are GALAXY 15 at 133?W and ANIK F1R at 107.3?W. You can discover your look angle to those satellites using a calculator such as the one at
http://satcalculator.freehostia.com/
For the eastern United States, generally the look angle is better to ANIK F1R, so most GPS receivers should prefer that WAAS signal (which is PRN 138). Users in the western United States may find GALAXY 15 is better (which is PRN 135).
