50 force motor
fish_addict707
hi, im wondering how hard it is to service the 50 force motor on an 87 bayliner capri? what are the steps and how much would it cost? thanks!
roscoe
Re: 50 force motor
Service it? To what end? To accomplish what? What do you need serviced?
There are a lot of things you can have done to it, what does it need?
Leaking oil?
Where?
Color?
Smell?
What kind of oil?
TCW-3 oil residue from the fuel?
Lower unit gear lube?
You are gonna have to give us a little more to work with.
If you are gonna work on it yourself, you will need either a factory or a Clymer service manual.
We can help. but the manual is gonna walk you through things in detail.
fish_addict707
Re: 50 force motor
Leaking oil?
Where?
Color?
Smell?
What kind of oil?
it looks like its oil mixed with fuel. kind of like a brownish color
roscoe
Re: 50 force motor
Black or dark brown gassy smelling oil is typical and normal.
It is a mixture of the unburned exhaust residue.
It exits the powerhead and flows out with the cooling water discharge, thru the motor leg.
The residue often builds up in the leg and lower unit.
It then slowly drips out, usually thru one of the weep holes or a seam between the leg and the lower unit.
Does no harm except for to leave a stain on the driveway.
fish_addict707
Re: 50 force motor
ohh ok. thanks! oh now im noticing white smoke also, is this normal? sorry for all the questions, i just bought this boat and hearing about bayliners n force motors is tempting me to get rid of this boat. and how fast should i be going on this boat with 2 or 3 people on it? there is also corrosion on the spark plugs.
olsenk514
Re: 50 force motor
White smoke and corroded spark plugs would suggest a blown head gasket. Not too hard of a job if you're mechanically inclined
