I can only get my 50 hp Chrysler outboard motor to start while choked, when I release the choke it dies.<br />I’ve replaced both coils, both condenser, and both set of points, timing 28 degrees before top dead center, 150 pounds compression each cylinder with throttle wide open and 140 pounds compression at idle, fuel pump is pumping good and have completely cleaned the carb, etc. Can’t figure out why it won’t run, anyone have any suggestions?
