50 hp force hard warm starts.
Donczar
My 1994 force 50 hp starts great when cold. It runs smooth at all RPMs. When I turn it off to fish and than try to start it after 15min to 1 hour it won't start. What I have to do to get it started is full trottle and crank for about 15 to 30 secounds which I hate to do.<br /><br />Anybody have an idea on what to do?
roscoe
Re: 50 hp force hard warm starts.
Very common problem. The engine is flooding.<br />The diaphram in the fuel pump is leaking/torn/perforated/ has a hole, etc. Seems these things fail atfter about 10 years of use.<br /><br />When the engine is warm, pump is full, fuel leaks thru the diaphram and the back of the pump and into the crankcase, which floods out the motor.<br /><br />You will have to look at your motor and see if you have the newer square style fuel pump, or the older round style. <br /><br />Get the Mercury diapham kit, I like them because they come with instructions. Easy to install.<br /><br /><br />You can pick one up at your local Mercury dealer for about $10.
Donczar
Thanks that did it .Also I notice the hose clamp for the fuel was bad.
roscoe
You're welcome, happy boating.<br /><br />Thanks for letting us know how it turned out.
