Re: 50 hp force
Disconnect the black with yellow stripe wire from the terinal strip,(port side of block)and try it. This eliminates the ignition cutoff and safety switches,and all associated wire harness. If the engine starts, you won't be able to shut it off, however...so be ready to choke it or disconnect the fuel line.
