My other/ past boats have power trim/tilt, and my new (approx 1980?) 50hp Mercury w/ manual tilt has me baffled. It arrived raised (& locked upright with lock-tabs) when I got the boat. To manually lower it, I unlocked/turned the locking tabs & moved the throttle lever forward (as I seem to remember an old fishing buddy's Merc outboard needing to be in gear to raise/lower the motor). After I lowered the motor down, the throttle is stuck in forward gear & wide open. Also, the steering wheel won't budge. It seems that all cables are locked somehow & I can't release anything to free them up. If I yank extremely hard on it, I can raise the motor back up, but it seems like the hydro pistons are resisting this.<br /><br />The only way I can get the throttle lever to move is by moving the little lever on the outside of the throttle (I thought this was a neutral rev lever), so when I move that lever all the way up, the throttle will slide back to neutral/reverse, but then the outer lever gets locked in the up position.<br /><br />Obviously, I'm clueless on the workings of this motor/controls setup & have no owners manual or even contact w/ the boat's original owner to help me out. Can anyone out there offer any advice? What is that outer lever by the throttle? And is there some magic release lever somewhere I'm missing? Thanks for any help.
