I bought a boat last fall and have been fixing it all spring...it has a 50 hp merc outboart sn c3243903, could you tell me what year it is. It also has a low power problem, I have pulled the plug wires independently and found that only the top two plugs seem to make a difference in the operation of the engine, I have built new wires for it and all 4 plugs have got a good spark, I did a compression test last night, (75 - 85 psi), also when adjusting the idle mixture the bottom carb of 2 does not react to the adjustment, could I have a bad carb?
thankyou in advance for any information.
