Re: 50 hp NO SPARK ahhhh
LOL yes they were grounded, but thanx Tator for the input its more than I got from any one else, So after hours of trouble shooting i have come a bit farther. I have check the DVA on the blue stator wires, and a red stator both tested out OK. the the rectifier seemed to ohm out kinda sketchy in ohm test mode but I dont have a diode setting on my multimeter. I have good connections one the battery and at the head, Good ground. The kill switch line did not effect the spark. Both coils Ohm out a 900 and that is to spec. The lower coil pack sparks, it was just to bright earlier to see that it was, the top one was not so to ensure that it wasn't the upper coil pack I connected the input on the lower coil to the top coil and sure enough the the top coil sparked. therefor the lower green and white wire coming from the switch box sparks the lower coil and the all green one is not triggering the top coil. Its a little odd though, the one pack that is sparking seems to be inconsistent as in its like it misses a spark once every thirty sparks or so, or I just cant see it, pretty sure its in consistent though. Otherwise I would have thought it would have ran on just one cylinder. So could it be a rectifier cause I can get a universal one at radio shack for five bucks vs the 300 for a new switch box. Or is it the switch box if there is no energy coming out of a wire on it ie the one to the upper coil pack.
