50 hp PowerHead Compatability
Alumarine
Hi there. I have a 1966 50 hp that's worn out.
I can pickup cheap a mid seventies powerhead. Don't know the exact year.
Will the new powerhead fit?
thank you
Laddies
Banned
Re: 50 hp PowerHead Compatability
There are basically 2 types of 44 cu.in. powerheads long and short cranks, yours is a long crank meaning that has a belt driven ign. system any long crank engine should bolt but may need minor changes. Your best bet would be a completely dressed engine so if anything is needed you will have it.
Alumarine
Laddies, thanks for your info.
The donor powerhead is on a complete engine with a bad gearcase (short shaft - I need a long shaft).
Does that mean if it's a short crank I should be able to get it to work (assuming it works) because I will have all the "pieces"?
Thanks again.
Laddies
Banned
No, you can still make the change when you have ever thing even to a short crank engine, the short crank is any engine with the 4 coils they shortened the crank as there was on need for the ign. drive pulley and put the new style stator with the trigger under the flywheel.
Alumarine
Great, thanks again.
Will post outcome.
