50 Johnson lean sneeze!!
Rodman738
I recently did a power head swap on a 1988 Johnson 50 Hp tiller.
It has a lean sneeze or backfire at lower rpm that sometimes stalls the motor.
I have swapped power pack,coils, ignition sensor,carburetors, plugs.
There isn’t any lean adjustment on carburetors and the small orifice is clear on both carbs.
Any advice would be appreciated!
jimmbo
Could be a leaky Gasket between the Carb and Intake, and/or a leak between the Intake and the Crankcase. Link and Sync out of adjustment. Low Float Level, bad Gaskets in the Carb, dirt/Gum/Varnish in the carb circuits, to name a few
Where did the replacement powerhead come from ?----Are both throttle plates closed at idle ??----If they are not closed , the idle circuit does not work.
