50 Merc cowling question
Nos4r2
Re: 50 Merc cowling question
Yes but you might have to tap the bottom of the frontplate up a bit to get it to locate. I've just put a full '73 cowl on my 4 coil 80's 50hp as it doesn't look quite as appealing to thieves.. If you've got the 4 coil model check that your spark advance doesnt foul though if you're using the top cowl. I had to take the grinder to the inside and clean off a few redundant bits of casting.(excuse the excessive copper grease on everything I hadn't cleaned it up when my g/f took the pic...
Silvertip
Neat motor stand. Just curious -- how fast does that old Merc pull your Daihatsu? :)
Nos4r2
Not sure-the darn thing sinks before I can get to WOT :D
