Re: 50 Yamaha - Won't start - Help!!!!
Ahoy, bigg-O.<br /><br />Start by checking for spark. Pull each plug and see if each will arc a 1/2 to 3/4" hot, blue spark to the block. While they are out, check your plugs for wetness.<br /><br />No spark? Disconnect ignition kill wire and check again.<br /><br />If you have good spark on both, check your starting procedure. Wet plugs that are firing suggest flooding. Dry plugs suggest too lean or no fuel mix getting to the cylinders.<br /><br />If the plugs are firing but dry, try spraying some fuel mix into the carb throat.<br /><br />Let us know what you find, and we can proceed from there.<br /><br />Good luck.
