50A Red Button On Top Of Engine
brsox88
Should you be able to push this 50A button on the top of the engine? I assume its a breaker/fuse of some sort for the main engine harness, or is it a kill switch of some sort? I ask because mine does not move and I want to make sure that is as intended.
GA_Boater
What engine?
Sounds like a circuit breaker on Mercruiser, OMC or Volvo-Penta. It only moves if it tripped.
alldodge
If its the 40/50amp breaker it doesn't move unless it trips, so if you press it and its not moving you should be good, unless you motor has no power.
Looks something like this?
brsox88
Yup, thats it! Thanks for clearing that up. Wanted to make sure it was stuck from corrosion or something.
