I bought a 1980 50 hp 4 cyl Merc that had very little use. It is so clean under the cowl, you could eat off it, and it really does look and run like a brand new motor.
But I am concerned about the cooling. I cleaned out the water discharge tube----was plugged up from insects---and now that pisses out an abnormally strong stream of water. But that stream is VERY hot. I cannot hold my fingers in it. My other outboards, including the 1990 40hp I currently have only had a "warm" stream.
I am going to change the impeller, just on general principles (if its original, it is 36 yrs old). But should I be looking for something else? The telltale stream is way stronger than what I consider normal, and its way hotter than normal. Could I have some blockage somewhere (more insects??) Don't think this engine has a Thermostat, but maybe it has a poppet valve somewhere that is stuck??
Would like to fix this before I ruin a spotless older motor. What should I be looking for? Any and all advice would be much appreciated
