50HP E50TLEUC shift lever screw taken out!
corso77
My father in-law gave my wife and I his boat, before winter he drained the lower gear case oil. Don't think he had done it before or had been a long time. He removed the screw just above the very bottom that you should to drain the oil. Its listed as screw 55 in the manual's I can find. The problem now is it won't re-screw or get tight. I'm assuming it should be tight else it would vibrate out. Is there anyway to get this tight without dropping the lower unit. From what I've read its either the alignment of the two parts the screw goes into or its stripped. Assuming its the alignment is there anyway to get it tight without major work?
Stop.----You have to be very careful.----The thread for that pin is way inside the gearcase and easily damaged.----Time to remove the lower unit.-----It needs a new impeller anyway.-----Lay gearcase on it's side.-----Then gently move the shift rod and you might see the hole line up.-----Or visit a shop that has seen this before.
oldboat1
got it yet? a punch or finishing nail can help to get it into exact position. Lots of patience may be required.
