Re: 50hp early Force parts fit 55hp1973 Chrysler?
Here's a points ignition Chrysler 50 that is doing 45 MPH. No problem with that baby.
Buying a new rod and piston would not be cost effective. The rod is well over 200 bucks and pistons run from 70 up to about 125. So, you could have 400-600 invested in an engine that on a good day would sell for 500
Nothing is wrong with points ignition. They ran very well for years. The electronic is a little less maintenance and perhaps a tiny skeench more power is delivered by the engine, but not enough to warrant stripping your 55.
The rods are the same from any Chrysler or Force from 20 up to 150 Horsepower with the exception of the late Force 90 and 75 so if you find a junker, you could salvage a rod from that.
If the piston is 3.187, you need to buy a new one or again, find a 50 or 55 to salvage one from. If it is the big bore 50 with 3.375 bore, then the piston would come out of a 120 or again buy a new one.
I'm not sure how the electronic ignition on the 50 is but I THINK the crank is different since it does not have a slip-on cam. SO: you would possibly need to change the crank if you wanted to change the ignition--too much work for too little gain.
However if you see that the crank nose is the same then the whole ignition might just swap with just a couple of mounting holed drilled on the top of the block--this is for you to see and decide.
