50HP fuel connector - where to buy?
MattFL
Master Chief Petty Officer
I need the female side (fuel tank side) fuel connector for my 1999 50HP Honda. The part number for both sides (fuel line side and motor side) is 04104-ZW9-010, but it's $43 and I don't need both halves, I only need the fuel line side. Does anyone know where I can get the OEM part for the fuel line side only? Here's the kit with both sides.
MattFL
I searched for "Honda outboard fuel connector" and came back with several
WALMART
Thanks I might have to give that a try. It doesn't say the year, and I've noticed for whatever reason the one that fits my year has been difficult to find, but for $10 maybe it's worth a try.
airshot
I always use OEM parts for my outboards. Aftermarket especially Chinieusm made parts typically don't work well. Leaking fuel on my boat is not something I want to experience. If 45 bucks is to much then a boat might not be a good hobby for you. Nothing about a boat is cheap, if you want it to work correctly.
Consider switching to Mercury fittings.----Might be easier to find.
rolmops
I would bite the bullet and spend the $43. If one side has gone bad, the other side probably has some damage as well.
