50hp Johnson-1999 Fuel Pump Problems?
Spicnspann
Ran out of gas and since have had problems with throtling up. Idles good, but when you throtle up it looses power. Was told that it was the fuel pump and was also told that it could be as a result of the oil continuing to be pumped into the engine.<br />Need suggestions and also the approximate costs on a fuel pump.
JB
Re: 50hp Johnson-1999 Fuel Pump Problems?
To Johnson Troubles.
