bonz_d
- Apr 22, 2008
- 5,276
I have a Lower unit I'm trying to test. Not sure of the year but it is white and does not have the anode filler block above the prop So I give it a year range of 1977 to 1982.
Ran it in the water yesterday, It will not shift into reverse, almost like it is not shifting far enough to engage. While when stifting in to forward it almost seames like it is engaging early. Forward gear is solid and does not jump or jerk like I have seen with a bad clutch dog.
The engine is a 1983 60hp that with the original lower has no issues and shifts just fine so I don't believe it's in the shift cables.
Could it be the shift rod out of adjustment and if so does anyone know the measurement as the manual does not list it.
