Not sure if maybe there's a clog somewhere.
7 777funk Petty Officer 2nd Class Joined Jan 12, 2015 Messages 150 May 8, 2023 #1 Not sure if maybe there's a clog somewhere.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,757 May 9, 2023 #2 Drop the lower unit and make sure the key is in the impeller. Then install lower unit and make sure the water tube is inserted into the water pump housing. Put motor in lake or tub of water, make sure water pump is submerged in water.
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 18,078 May 9, 2023 #3 Using muffs? Some muffs don't always work right, tape it in place.
7 777funk Petty Officer 2nd Class Joined Jan 12, 2015 Messages 150 Dec 1, 2023 #4 Old thread but I think his problem was that we didn't have the lower unit aligned with the water pipe. He made sure all lined up and it works.
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,313 Dec 2, 2023 #5 Thanks for coming back to put closure to this
