throbinson1
- Aug 2, 2017
- 2
I have been working on my '76 Chrysler 55 hp outboard. I replaced the stator, the ignition switch (w/ key), the Magnapower Ignition Box and cleaned out the carb.
It fires up and idles great, so... I took it out on the water. Problem is, when I throttle up it bogs down and runs steady like that for a minute or two (real slow). It then starts to power up then dies. It floods so I had to wait a couple minutes. It then restarts easily and idles well. Then again, I throttle up and after a bit wants to power up then dies/floods.
I had about half a tank (3 gallons of gas/oil) in it from last August. I put another 2 gallons of fresh gas/oil in it.
Any idea on what is causing the issue? Thanks!!
