55 hp chrysler model number location
electric603
Can anyone tell me where to find the model and serial number on my 55 hp chrysler? I found a number stamped in the engine K878855 but that does not seem to match any model numbers I have seen online. Thank you.
Nordin
Re: 55 hp chrysler model number location
If you have a 55Hp singel carb engine there should be an Id.tag plate in the lower cowl just infront of the carb. If you have a 55Hp twin carb engine the Id.tag should be rivet on the powerhead near the lower cowl/leg.
rdevoto
Still can't find it. No plate riveted on cowl.
Nordin
Well, okey post pics of the engine, specilly the hood then I maybe will be able to help.
its on the inside of the bottom cowl almost right where the lock comes up..
