'55 Johnson 5.5 gas can
Craigponder
The gas can hook up on this is not like the modern 2 prong . Can some one point me in the right direction. 2 hose type?
F_R
The twin hose pressure tanks were not used since 1959 and often are worth more than the whole motor. Your best bet is the Antique Outboard Club www.aomci.org.
Crosbyman
you have 2 option ... chase down a two line hose and connectors and.. .the 2 line hose thank which works with pressurized air from the motor.
the alternative is to modify you 5.5 for single line operation by installinga single line side connector , modifying the pressure system and mounting a smal pressure pump which will pull fuel from a modern tank instead of the old way of pusing air in the tank to have the fuel return up to the carb ...
sounds a bit complexe but isn't see utube
