55 Rude wont idle down
A 55 Rude that will start at real high Idle ,but when i bring it down to shift it dies. this engine had suffered an overheat and took out the power pak and some misc. wiring. Coils check out o.k. along with timming . It acts like an air leak ,but have gone over it looking for leak. Is there a way to prove if it is sucking air at lower speed? thanks John
jonesg
Re: 55 Rude wont idle down
Try a compression test, low compression will show up at idle and cause symptoms similar to advanced timing ( high idle speed).
I'd suspect a compression leak ,
due to the overheat stretching the bolts in the head and warping the head.
I had a similar problem, I tweaked the head bolts down and it went away.
Did you fix the waterpump?
kenmyfam
Basic health check to begin with.
Compression
Spark
Fuel delivery
Spark plug condition.
Go from there.
