55hp chrysler model 559hh engine specs
moorbee
I have a 55hp model 559hh chrysler approxematly 1977 year which i have pulled down to find a knocking noise which turned out to be piston slap, as the piston clearance is running between 8thou and 16thou which is way to much to my understanding. But i have decided to re assemble the engine as it is not worth spending money for new pistons and reboring on such an old engine. My question is can any one tell me the toque settings for the Head, big ends, and crank case studs. <br />And does any one know what the piston clearance should be. Thank Heaps any one with info<br />regards Moorbee.
12Footer
Re: 55hp chrysler model 559hh engine specs
Headbolts are 270inch pounds.<br /><br />con rods are 180-190 inch pounds<br />Crankcase studs, 70in pounds
steelespike
My info up to 1972 is .005 piston clearence.
