55HP Electric Shift Solenoid Buzz
fpan
I needed to re-wire the two solenoids as the blue wire (neutral I think) was shorting out. Once re-wired reverse clicks but neutral buzes. With the cover off I can just barely (and I mean barely) nudge the shift rod and neutral engages. The rod isn't bent. The plunger is in the hole at the bottom and I seem to have a good ground. Once I put the cover back on same thinf reverse works but neutral buzes like it wants to shift but can't. Getting kinda tired thinking of shimming the rod to give it the "nudge".
