tater76
- May 7, 2010
- 712
Ok folks, so this thread may need to be moved but lets give it a whirl here with the Chrysler Force guys. I have a 1973 55hp Chrysler model 555HF just rebuilt. (Here's the kicker) I changed out the ignition to an 1985 50hp Force stator ign. It runs like new and I am extatic about that. However, having only owned OB's for a few years I am new to the set up, ie.. transom mounting hights, etc. I ran the boat for 3 years as I bought it, no changes at all. As I got tired of 17-20mph I did some research as to possible fixes, and found out here, how to properly set up the Cavitation plate with the hull line. I went out to check/measure, and immeadiately saw that the cav plate was at least 4" below the bottom of the hull. I unbolted the engine, jacked it up to do some measuring. I had it lined up well, but the transom mount clamps are VERY close to the transom cap. My question is, can I get away with cinching it down so close to the top of the transom, or do I need a jackplate/repower? Here are some pics of the situation, and its really not that dirty, the grey stuff is bedliner that the previous owner/gomer applied to the whole topside. But that's another thread
Also, when the motor was moved I found two sets of holes. One set was higher than I had been running (about one inch), I just hate to punch holes in a boat if I don't have to, but I will if you guys think It's worth it.
