Calglass19
- Aug 24, 2008
- 12
Hi all.
just got a '69 Starcraft Jupiter, '69 Johnson 55 (Mod: 55ESL69A) and a '76 Johnson 6 (6RL76A) hanging on the back. The 6 runs like a champ, the 55 needs new fuel and new plugs. (It misses here and there.)
I was testing things out with my muffs, and the 55 wasn't showing water from the telltale. So I took the bottom end out to change the impeller. It was like brand new. New housing and all, no scratches anywhere. So I put it back in and searched the forums. Someone mentioned a thermostat, so I put a new one in. This time I ran the engine in a 55gal drum instead of muffs. (Someone said some motors. Won't pull water on muffs. Still no water from the telltale holes.
While it was running I had my eye on the HOT light, it stayed out. The head and block warmed up some, but never really got hot to touch.
Is this correct?
Will the telltale on this engine only spit when it gets hot enough to open the thermostat?
Any other thoughts?
Thanks in advance for any help.
Is this correct?
Any other thoughts?
