56 7.5hp starting problem
dtruck
Hello,When I pull the starter rope the throttle instantly goes from start position down to slow causing me to need a 3rd hand.Where should I look to correct this problem?
F_R
Re: 56 7.5hp starting problem
The coils are dragging on the flywheel magnets.
1. The coils are not adjusted flush with the machined edges on the armature plate, OR
2. The armature plate is flopping around loose. Maybe excessive wear, or broken, or the retaining ring is upside down (it goes flat side up). OR
3. The flywheel is bent from use of an improper puller OR
4. The flywheel is cracked or smunched way down too far on the shaft from tightening the nut with an impact wrench.
dtruck
Hey ,Thanks for the reply I actually figured it out before I walked back in and read this.It was number 1 buy the way. one side of one coil just a nat hair off the shoulder.Purrs like a kitten now.Thanks alot
samo_ott
I've seen #1 before. #2 rarely. Never 3 or 4. I guess I need to work on more engines!
dtruck
I bought a 30hp johnson one time and someone had I guess used a homemade puller or something and ran the bolts right down into the coils
bktheking
Or a drillbit!
samo_ott
Ya I found that after some googling, it's pretty funny!
I cant believe how many folks like it! I don't! haha. sorry... Oh well... I'm off to Cuba in a few hours... I'll be silent for a week...
Jeremy1986
i had the same problem with my 56 5.5 evinrude and finally figured it out.
