Hi guys, I was wondering if anyone has suggestions on the best fuel to use for this engine. I just picked this engine up and ran it on a jon for the first time today.
The owners manual states to just use regular and not high octane because the higher lead may cause issues. It also says to use either outboard oil or automotive SAE 30 (not heavy duty) or cheaper oils. The instructions for mixing says put 1 gal of gas in a 4.5 gal tank, add 1 qt oil, mix then fill the rest of the way with gas.
Now I realize these directions were from 1956 and a lot has changed, like most gas you find is ethanol crap. Which I've heard not to run, but there's little choice anymore.
I ran 87 octane today in a 6 gal tank and added 3 bottles of (16oz?) outboard oil. Think that was a 16:1 ratio which I was told to run. It ran fairly well for the most part; a little jumpy WOT though. Not sure if that was the gas or if I need to make some adjustments here and there.
Thanks
Thanks
