I noticed lube seepage on my 15 horse lower unit, so I decided to have a look inside and do a reseal. The good news is it didn't seem to have water inside and the gears, cluch dog, shift fork are all in excellent condition. The drive shaft is a bit worn at the lower unit seal, but it doesn't seem bad enough to worry about yet.
My dilemma is this... The seal kit came with a drive shaft seal that is the correct diameter, but about half as thick as the existing one in the lower unit. The original, which I haven't removed yet, is about a half inch thick. The new one is about a quarter. If they were available individually, I'd be tempted to buy another narrow one and install it on top of the other new seal. I think it would fit. It is the correct seal kit... bought it from Vintage Outboards online. Only that seal is different. The old seal doesn't look too bad, but I'm sure the rubber is somewhat worn. Have any of you run into this? Did the smaller seal hold up? Would I be crazy to just leave the orgininal one in?
By the way .. the seepage was coming from a small crack in the lower unit cap/skeg. I have a mig welder with an aluminum spool, and have welded aluminum before, but I'm a little worried about trying this one because there is no sure way to clean the lube out from the inside of that crack. I'm leaning toward JB weld for aluminum on the outside of the cap only, and looking for a replacement cap for later. If the JB weld falls off, I would see that easily before any damage is done. I don't think the crack is in a place that will let it grow ... but the more I think about that, the more I lean back toward welding it.
I'd appreciate any advice
Tom
Tom
