KathyD19
- Jul 17, 2012
- 369
I apologize for starting a new thread but I had no replies on my other thread (which had started with a different topic). I'm at the end of my rope and ready to sell this motor if I'm too stupid to figure something this basic out. Here's the scoop. I had to remove the upper and lower carb needles/packing nuts in order to remove the air silencer. Since the air silencer covered them as I removed them, I don't know how they looked prior to removal. Now I'm ready to put them both back in and I have purchased new washers because the lower had 2 degraded ones and the upper receptacle had none present. I placed 4 washers in the lower receptacle and was able to replace the needle/packing nut with no problem. The issue remains that the top packing nut will not screw in very far at all even before adding the washer and it's worse since I've added the 2 new washers. I am including pictures of how far it goes in, hand tightened. And at this point, the needle is still able to be moved by hand but if I tighten the pack nut any further, the needle can't be moved. I used a blunt metal dental instrument I had to measure the depth of the receptacle to the inner rim which would be the natural stopping point to the packing nut threads. There should be enough depth available but it just doesn't screw in any further (and knowing it's soft brass, I won't force it). I have to resize all pics that I post on here, for now I'm attaching a couple of it tonight, as far as it will screw in. I will resize some more and add them in a bit. Any suggestions or input is greatly appreciated.
