58 7.5hp johnson, smoking badly
kbert1171
at idle the mortor barely smokes, but when i crank the throttle, it smokes like mad. i mixed the fuel to 24:1, rebuilt the carb.
wondering if i should lean the fuel mixture out some???
flyingscott
Are You Running This In A barrel? It is normal for motors to smoke with more throttle. You Could try leaning it out May help.
I would not even think about reducing the amount of oil in the gas !----You may want to turn the high speed needle in to see if smoke is reduced and performance improves.
kbert1171
i am running it in a barrel and i really dont want to lean it out, but the smoke is ridiculous. ive played with the high speed needle and the smoke stays the same. i also can not get it to run smooth at full throttle. no matter how much adjustment i make. what am i doing wrong?
kbert1171
it seems to bog down at full throttle for some reason. it might run fast for a few seconds, but then it bogs. i dont understand. when it ran last year, it never smoked like this.
First check if spark will jump an actual gap of 1/4" or more.-Does it , yes or no ?---Also , this motor has a " slip clutch " below the water pump and there may be issues ( binding ) at full throttle.
F_R
Without being there to witness it, I'll say it probably is missing on one cylinder. Whenever it does that, the fuel that did not burn in the cylinder goes out with the exhaust. Then all that oily mess in the exhaust housing burns and smokes like crazy. Check your ignition system to see why it is not firing both cylinders.
F_R
BTW, the gas/oil ratio for that motor is supposed to be 16:1. That's 1 qt of oil per 4-gallon tank. People can and will argue about that forever. You decide.
People will argue forever because the lubrication of a 2 stroke engine is not well understood !
kbert1171
ok. at the risk of sounding ignorant, and because i am on this particular subject, how do i test this 1/4' jumping spark gap?
i have spark from both plugs. weather its hot enough or whatever, i do not know.
oldboat1
16:1 for the 7 1/2. With a clean carb, the h.s. needle usually ends up between 1/2 and 3/4 open in my experience. Can't (shouldn't) rev in a barrel, though. Pull off boots one at a time and see if you get any rpm change. Check spark with an adjustable tester. Set the tester for 1/4 inch. Use Champion J4Cs gapped at .030.
Crosbyman
run it on the lake and let it rip....
did you service the electricals and adjust everything
breathing it's own fumes in a barrel doesn't help performance
run cheapy oil or good stuff ?
Crosbyman
TR.OD High Energy Ignition Spark Plug Tester Auto Car Test Pencil Circuit Diagnostic
https://www.amazon.ca/Energy-Ignition-Tester-Circuit-Diagnostic/dp/B077XK831Z/ref=sr_1_14?ie=UTF8&qid=1520717485&sr=8-14&keywords=spark+tester
I recall 2 gentlemen much older than myself at the time bringing one of those motors in the shop.---They both said " we can't get the carburetor adjusted right "------Turns out the head gasket was blown !----So do the trouble shooting with first a compression test.---And that 1/4" spark test.-----That incident was about 50 years ago.-----Those motors run really nice when in good shape.
kbert1171
spark test confirmed the top coil is bad. i will replace it and most likely the points and condensers and try it again. thank you all for your helpful advice. ill post the results when the work is completed.
oldboat1
Just a heads up — if you believe one coil is bad, it would be reasonable to replace them both. (I would hang on to them unless the casings are cracked and breaking up. Do a search here on coil testing, as there is some testing you can do with a multimeter.)
If it were me, I would replace coils, points, condensers and wires at the same time — also the boots if they are dried and cracking. Confirm strong spark, then move on to other systems if needed. If the motor is new to you, you need to replace the impeller as a priority. (The powerhead needs to come off to access the shift rod connector, but not a difficult job.)
Chinewalker
It's supposed to smoke. A lot. It's also next to impossible to get a wide open carb adjustment in a barrel. As mentioned above, get it on a boat and dial it in there. Only then will you know if you actually have an issue or not.
