fletcher123
- Jun 18, 2010
- 57
I bought a 14ft boat with this motor on it. it's a 58 gates buchaneer electric start 35 hp. sat for the last 4 yrs. I changed oil in lower unit and got it to start up to see if waterpump works etc. When you are at the back of motor on left side of lower unit where it bolts above the propeller a little oil is leaking around the bolts does this mean it needs a new gasket or some type of sealant to fix? also it seams it is not pumping any water at all. i have a large barrel with waterline a couple inches above the plate on the left that has 4 small holes in it. Do i have waterlevel high enough to test? I cannot find anywhere else that it would suck water in. Would there be a filter of some sorts to check or clean for the water pump accesible from outside of motor? I need a manuel and since this is my first boat owned I know nothing but very mechanical with regular 2 strokes of atv/motorcycles. any info would be greatly apreciated.
