1958 Johnson Super Seahorse 35hp RDSL-20<br /><br />I've gone over this motor, including installing a new impeller and water pump housing. I just pulled the thermostat and tested it in a pot of hot water with a meat thermometer ... it works perfectly. I then left the thermostat cover off and started the motor briefly to watch for water being pumped ... There wasn't a drop. Not even a drop. The intake screen was clogged looking when I started this poject, so I poked a bunch of holes in it. I guess that could still be a problem. Before I pull this lower unit again, is there anything else that might be causing this problem? I still need to adjust the carburator, and fix a small leak in that, but the motor fires up first time, every time and runs great for the short periods I've let it run.<br />Thanks for any suggestions<br />Tom
