59' 35 hp cutout wiring
electric603
I just bought my boat with this engine on it. Previous owner said engine did not have spark. When I took the coveyr off I noticed the wires for the cutout button and the wire on the mercury switch were disconnected. Can anyone tell me where they go or does anyone have a diagram? Also there is no starter on this motor. Can I put one on it? Thank you.
Beek14
Re: 59' 35 hp cutout wiring
This is a 1959 35 hp Johnson or Evinrude? If so, there should be two leads with snap clips that come from the magneto that plug into the kill switch leads (that complete the circuit and the button cuts out the power as it is pushed). Very simple design on those but very efficient. Does the outboard have a manual recoil starter on it?
electric603
Yes, it is a Johnson. It has a pull start on it. It looks like there's only one lead comming from the magneto. Does the other. lead from the button connect to ground? Thank you for the reply.
HighTrim
Here is a wiring diagram for your motor, it is for electric start though, so edit it as required. You can get electric start on your motor, with a few purchases. If the coils are original, they are dead and will need to be replaced. Pull the inspection window on the flywheel to view them.
F_R
Kill button substitutes for the two "M" terminals on the key switch. You will have a single mercury switch, ignore the second section which is only on electric start models.
electric603
Thanks F_R and High trim. The diagram is just what I needed.
