'59' Super Sea Horse questions
nicnbj
I am going to replace the points, condenser and ignition coil, what special tools will I need once the starter assembly has been removed (aside from the basic wrench and sockets)? The manual says flywheel puller but I'm sure I will need other tools. Also, do I get all these tools from any tool store or do I need to go to someplace special? Any comments about prices would also be of help.<br /><br />Thanks,<br />BJ
daveswaves
Ensign
Re: '59' Super Sea Horse questions
You will need a screwdriver and a feeler gauge with .020" gauge in it to set the points. It sounds like you have the manual so just follow the instructions. :)
no clue
just out of curiosity,have you had any luck with parts for this motor.i own a 59 super sea horse 50hp.model numberv4sl-11 b.if you have the manual does it show a part # for the clutch dog
rolmops
double check if the lower unit on the '59 35 and the '59 fifty are the same(I think they are).<br />If so,the clutch dog # is 305105.<br />good luck.
Lark40
You need the flywheel puller and also a flywheel holder. These are available from local Evinrude and Johnson dealers. They are NOT cheap.<br /><br />Also, if you move the coils, there is another special tool you need to realign the coils called a locator ring, from the same dealers.
no clue
rolmops,thank you so much.ive been emailing every marine connection online to no avail.this is the first number anyone has offered.i hope its the same.thanks again
rolmops
It's a pleasure.<br />You should give the guys at twin city outboards a call not only do they know,they also have the part.<br />Their site is: www.tcoutboard.com<br />Their phone is :952-496-1951<br />Good luck.
Chinewalker
The 35 and 50 lower units are not similar - the 50hp leg is a monster.<br /><br />As for the flywheel puller, you can use a regular harmonic balancer 3-point puller. Use some 1/4"20 Allen bolts and some hefty washers to keep them from pulling through. Puller can be gotten at Sears, NAPA, etc.<br /><br />For aligning the coils, simply make sure the laminates are flush with the machined edge of the armature plate so that you can't feel the ridge with your fingernail...<br />- Scott
SeaMasterZ@aol.com
thank you chinewalker, I was having some serious heart palpitations over that post, whoa, WHAT??? the manuals didnt say anything about that!!! <br /><br />sheesh, holy heart attack, batman!<br /><br />ah well, a boat IS a hole in the water you throw money into!<br /><br />cept mine is a birdbath perched on a trailer you throw money into! (pick one, I have a few, lol)<br /><br /> :rolleyes:
