5L to 5.7L 1995 Larson now has vibration
only_1
I am curious if anyone has experienced a similar situation.
To start, I bought the boat as a pile of parts. It had a reman engine that had very low hours, but had been disassembled. He did not drain the block, so it cracked. I took the rotating assembly and put it into a new block, machined to match the old block. I assembled it and put it into the boat.
I got a vibration when it ran. I did compression check, and they were perfect. Spark at all cylinders was confirmed. Took the outdrive off to eliminate that as a contributor. Checked runout on the coupler. Swapped the harmonic damper with no change. All fine. Which is what I expected because other than the vibration the thing runs great. Vibration only occurs in the mid rpm range. Not very noticeable at idle or at high speed.
So I pulled the engine back out. Pistons with rods, bearings, caps and nuts had a weights ranging from 1449 grams to 1462 grams. Not great but not as bad I was expecting from the amplitude of the vibration.
This brings me to my question, do I take the assembly in to be rebalanced?
Have any of you bought a pre-balanced rotating assembly and dropped it into your block with success (no noticeable vibration)?
I don't know how the pre-balanced assemblies work with the mercruiser flywheel.
pull the drive, the vibration may be coming from the drive
as far as pre-balanced rotating assembly, its a "spec balanced" rotating assembly. 13 grams is a large difference, however not as bad as it could be because its a 29 gram window for a "spec balance"
did you take the rotating assembly from a 5.0 and put into a 5.7? the cranks are different (different bobweights)
[h=2]5L to 5.7L 1995[/h] I took the rotating assembly and put it into a new block, machined to match the old block. I assembled it and put it into the boat.
Ayuh,...... Welcome Aboard,....... So you took a 5.0l rotatin' assembly, 'n fit it to a 5.7l block,..??
If you've got it on the bench now, I'd haul it to yer favorite machine shop, 'n have it all balanced,.....
includin' the flywheel of course,.....
only_1
Sorry, I didn't fully explain. It was a 5.0 that was replaced with a 5.7l reman long block. So the crank, rods, pistons were all 5.7L components from that reman. I just put that entire rotating assembly into another 5.7l block that was machined the same way the cracked block was.
I did remove the outdrive and verified the vibration was in the engine.
only_1
Yeah, I am leaning toward having my current components balanced. I know it runs great with these items as it is. I already warned my machinist that I am probably bringing this mess his way. LOL
then take the whole thing to the machine shop to get balanced
your going to need new rings, gaskets and bearings.
