Re: 6.2l won't go faster than 45mph.
Well whe i tested the boat boat before I bought it. it had water in the gas, so I didn't really get on it. Then after I drained the gas and the fuel seperator, It didn't sound right. It sounded like it was missing. So I did a complete tune up, minus wires, which i'm gonna replace now! But it still sounded funny. So I did a compression test and found erratic compression in one cylnder. I was thinking broken valve spring. I took it it in and they found a bad lifter. So I had a guy put cam, lifters, and springs to cover it all. As far as if the cam he put in is what he said, I never did get any paper work showing specs. So I guess there is the possibility that he lied to me! I hope not! I think i'll be asking him for that! The guy that has done the work owns his own shop, and deals with both boat and automotive issues. He has experience doing engines, so I would think he broke the cam in right!... I hope anyway!
So I think I'm going to first check that the carb is opening all the way. If it is, then I'll check the fuel pressure. If all checks out there then I'll put a timming light to it to see if it's advancing properly! I don't think the Exhaust is restricted because when it's running the water comes out in a nice spray, and both sides look the same as far as water flow coming out..... P.S. I'm an idiot! it's not a 6.2, It's a 7.4!! A 454 big block!... Even more reason it should go faster than 45!
