6 hp evinrude fuel problem
buddie52
motor starts & runs well at high revs,but will not run at slow revs or idle.
can anyone help.the motor is a 1977 evinrude fisherman 6 hp
samo_ott
Re: 6 hp evinrude fuel problem
I assume you've tried to adjust the low speed needle (does a '77 have one?)
It might be time for a carb cleaning if not. It usually solves a lot of issues like that.
Vic.S
It does have a slow speed needle!
The initial setting is 1? turns out from ( gently) seated
See Joe Reeves instructions on the "Engine Frequently Asked Questions" board for adjusting.
If it wont idle at or near the initial setting then I agree carb clean almost certainly needed
