6 hp leaking
Old outboard dude
My 79 6 evinrude is leaking something, I'm not sure what it is but if you know please tell me how to fix it and what may need to be replaced
This topic has been discussed about 277 times this year.------If you do some research you will find that this is normal.
ondarvr
The exhaust is mixed with water in the midsection, there is unburned oil and gas and it mixes with the water, this gunk is thick and sticks inside the housing. After the motor sits for a while this gunk starts to slowly run down out of the exhaust housing and forms that ugly mess on the motor and floor.
​Some oils create more gunk than others, and running at low RPMs may cause more of it, so will a bad thermostat that doesn't let the motor warm up completely.
​It's very common, and normal.
There is a slight chance it's gear oil, gear oil smells bad, oil and gas smell like, well, oil and gas.
clemsonfor
Might be gear oil if it smells really bad, but likely it's just the oil two stroke oil and water and unburned fuel dripping out of motor
