60 horse merc no power under load
wxpnwo
60 horse merc 3 cylinder late eighties cant get any rpm under a load. goes to about half throttle and then boggs out. At idle it gets full rpm. changed the plugs rebuilt the fuel pump. I am at a loss could it be the powerpack, carbs, or just a small electrical problem. Pleases help.<br /><br />Thanks<br />Dan
bigbrownbuku
Master Chief Petty Officer
Re: 60 horse merc no power under load
those engines were prone to exhaust clogging right under the powerhead.<br />if you have good compression and spark(correct timing) and your carbs have been cleaned and setup well you may want to look in this area
