60 HP 2 stroke running rich and fouling plugs
crbuckjr
My 2 stroke 60 HP Yamaha runs great then plugs get fouled after 4-5 hours. Plugs look oily. As a semi-novice, can I adjust the fuel/oil mixture without getting into too much trouble? If so, how? Or do you have other ideas?
thanks a bunch
99yam40
is this a oil injected motor or a pre mix?
Could be running too cold and fuel is not burning properly or too much oil
TheCat1212
does it have a fuel enrichment system? if so, make sure the red lever is in the normal position (not manual/emergency enrichment)
